# Page Not Found
The URL `using-ndi/ ndi-advanced/encoding-and-decoding` does not exist. This page may have been moved, renamed, or deleted.
## Suggested Pages
You may be looking for one of the following:
- [Encoding and Decoding](https://docs.ndi.video/all/getting-started/white-paper/encoding-and-decoding.md)
- [NDI Encoding Support Matrix](https://docs.ndi.video/all/using-ndi/ndi-for-video/ndi-encoding-support-matrix.md)
- [Installing NDI Tools](https://docs.ndi.video/all/using-ndi/ndi-tools/installing-ndi-tools.md)
- [Products Using NDI for Audio](https://docs.ndi.video/all/using-ndi/ndi-for-audio/products-using-ndi-for-audio.md)
- [NDI Video Codecs and Format Matrix](https://docs.ndi.video/all/using-ndi/ndi-for-video/ndi-video-codecs-and-format-matrix.md)
## How to find the correct page
If the exact page cannot be found, you can still retrieve the information using the documentation query interface.
### Option 1 — Ask a question (recommended)
GET https://docs.ndi.video/all/getting-started/white-paper/encoding-and-decoding.md?ask=<question>&goal=<user_goal>
`goal` is what the user is ultimately trying to achieve, the reason they need the answer. Sharing it helps GitBook give you a better, more relevant answer. A goal is most helpful when it describes the outcome the user wants rather than restating the question. For example, with `ask=how do I create an API token`, a goal like `build a script that syncs our docs to a CMS` lets GitBook tailor the answer to that use case.
### Option 2 — Browse the documentation index
Full index: https://docs.ndi.video/all/sitemap.md
Use this to discover valid page paths or navigate the documentation structure.
### Option 3 — Retrieve the full documentation corpus
Full export: https://docs.ndi.video/all/llms-full.txt
Use this to access all content at once and perform your own parsing or retrieval. It will be more expensive.
## Tips for requesting documentation
Prefer `.md` URLs for structured content, append `.md` to URLs (e.g., `/all/getting-started/white-paper/encoding-and-decoding.md`).
You may also use `Accept: text/markdown` header for content negotiation.
